Activity Forums Compression Techniques Compression Master and BitVice
  • Compression Master and BitVice
    Posted by Scott Simmons on May 17, 2006 at 6:52 pm
    Hello! While trying to find the cleanest encode to DVD from my HVX200 HD footage from Final Cut Pro…. I’ve used Apple’ Compressor of course but I’m also testing Compression Master and BitVice.
    Compression Master seems to give me lots of muxing errors…. anyone using either (or both!) of these 2 products for mpeg encoding for DVD? What are you results?
    Scott Simmons replied 20 years, 3 months ago 2 Members · 2 Replies
  • Scottieb
    June 2, 2006 at 9:29 am
    I assume you mean muxing errors in DVDSP? I’ve had the same issues.
    I personally really like using BitVice – it gives very nice results at relatively low bitrates – but have found that it isn’t worth using unless you have a lot of material that you need to squeeze on one disc and/or have lots of time to turn on extra features and render (overnight, usually).
  • Scott Simmons
    June 2, 2006 at 2:04 pm
    Thanks ScottieB.
    The muxing errors do arrive in DVDSP. But it is only on the material encoded by Compression Master. As for BitVice, I was surprised that the quality wasn’t near what Compressor did. It was the trial version but I expected better results. I must be doing something wrong.
    It seems no one uses Compression Master as I haven’t gotten a response on ANY board about it.
