Activity › Forums › Apple Final Cut Pro Legacy › compression markers – apply to the timeline or on the clip itself?
  • compression markers – apply to the timeline or on the clip itself?
    Posted by Paul Nevison on June 6, 2006 at 10:21 am
    just a quick one…when adding compression markers should the clip be selected in the timeline thus graphically adding the marker to the clip, or just the timeline selected thus graphically adding the marker to the top bar of the timeline?
    thanks
    (apologies for the cross post but need an answer urgently on this one and the fcp forum is usually more frequented than dvdsp)
    G5 DP 2.0
    4.0G RAM
    OS 10.4.6
    QT 7.0.4
    FCP 5.0.4
    BMD Decklink Extreme 5.5.1
    PAL Land
    Paul Nevison replied 20 years, 3 months ago 2 Members · 2 Replies
  • Jamie Worsfold
    June 6, 2006 at 12:14 pm
    The timeline 🙂
    jamie@jambonfilms.co.uk
    jambonfilms.co.uk
  • Paul Nevison
    June 6, 2006 at 1:46 pm
    thanks for the response
    is that still the case if i am exporting only a portion of the sequence as opposed to the entire sequence? I found the following in the online help files
    “Compression markers will export differently depending on whether you
