Activity Forums Compression Techniques Compression marker question
  • Compression marker question
    Posted by Kozo Okumura on September 17, 2007 at 4:34 pm
    In FCP, when you directly send the sequence to compression, my understanding is that it automatically adds compression markers on edit points.
    My question is that if you export the sequence as a quicktime movie with markers setting to be “compression marker”, are the compression makers embeded automatically on edit points as well even though the compression markers are not added manually on the sequence.
    Anohther question is that when you nest the sequence and export directly to the compression, do we get the same result from exporting directly without nesting?
    thank you
    Kozo Okumura replied 18 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
