Activity › Forums › DaVinci Resolve › Compression issues with S-log 3 footage low light
Marc Wielage replied 10 years, 5 months ago 4 Members · 11 Replies
Marc Wielage
April 25, 2016 at 1:30 amVery dense blacks are a huge challenge for any compression engine. My response would be to try to go for an image hosting site that has less compression. Vimeo Pro might possibly be a solution.
If you put up some test signals with just a black screen or various shades of gray, you’ll often see the same problems. These are known compression artifacts. Compression is evil.
There are also issues with 8-bit video in general from DSLRs, but if what you see on your own display is good, and it got a lot worse online, clearly the problem is the online compression. Whether you can change your own compression method would be a question of experimentation.
