Activity Forums Adobe Premiere Pro Compression issues for win media player 9 renders
  • Compression issues for win media player 9 renders
    Posted by Claron Werner on June 30, 2005 at 7:21 pm
    Hello!
    I have been using Adobe Premiere Pro 1.5 to edit and render out a series of video interviews that are generally 2 to 4 minutes long with light graphics and cross disolve transitions.
    I have been using the export Adobe media encoder feature and using the WM9 NTSC 512k Compression in its default configuration.
    Most of the time this works perfectly well for me, yet sometimes it seems that the compression breaks down usually towards the end of an interview. When this happens the subjects face starts becoming pixelated and the jpeg slides that I use also become very pixelated. It looks like the compressor just sort of quit working toward the end of the process.
    Once a particular film shows this problem it will not render out properly. I have tried restarting the program and computer, and tried different compression schemes but all appears to be in vain. Does anyone have any ideas about what I may do to fix or work around this problem?
    Thanks in advance for your time and knowledge.
    Have a wonderful day!
    Claron Werner replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
