Activity Forums Compression Techniques Compression issue with JPEG motion builder file
  • Compression issue with JPEG motion builder file
    Posted by Krisztian Majdik on December 29, 2010 at 8:07 pm
    I am scratching my head over the following issue and it’s most likely a simple oversight on my side.
    I exported an animation file out of motion builder in 24fps JPEG format. I am importing it into compressor 3.5 and plan to convert it into a 24fps prores proxy file for editing purposes in FCP. For some weird reason it keeps exporting it as a file with 3428 frames instead of the original 4281. Settings are the same as original, 24fps.
    What am I doing wrong? If I import the same file into quicktime 7, it exports it in the correct length and format.
    – Krisztian
    Krisztian Majdik replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
