Activity Forums Apple Final Cut Pro Legacy Compression (Formatting) – Transferring files
  • Compression (Formatting) – Transferring files
    Posted by Kevin Williams on October 28, 2010 at 5:50 pm
    I have a 5GB mov created in FCE that I need to move from my MBP to a PC. This file refuses to copy to a flash drive. i’ve been told it’s too large. How can I format (compress?) this file for transfer and it still look good being shown over SD projectors?
    Kevin Williams replied 15 years, 10 months ago 3 Members · 4 Replies
  • Todd Gillespie
    October 28, 2010 at 6:11 pm
    Try compressing to .h264. It will look reasonably well and be a much smaller file. But do check on the PC to make sure that the file can play in realtime.
    Good Luck,
    Todd at UCSB
    Television Production
  • Richard Keating
    October 28, 2010 at 6:44 pm
    I think you may be using the wrong codec/setting when compressing. You’ll want to make an H.264 QuickTime in Compressor. First, export a non self-contained reference movie from Final Cut. Take this file into compressor and do the following:
    Apply the H.264 preset (Settings>Formats>QuickTime>H264 QuickTime) to your file. Select your file with newly applied preset and click the Inspector. Change the settings to these:
    Click the Encoder Icon: Video: Settings:
    Frame rate 30
    Data rate: Restrict to: 1000 kbps
    (Drop this data rate if you want your file to be smaller, but you will sacrifice quality.)
    Make it Two Pass
    Audio: Settings: Target Bit Rate: 192 kbps
    Click the Geometry Icon:
    Dimensions:
    Frame size: 640×480 (or 854×480 if 16:9)
    Pixel aspect: Square
    Just need to make sure the PC has QuickTime installed and you are good to go
    Good luck.
    Richard Keating
    Editor, Co-Creator of ScreenLight
    “Painless Video Review and Approval”
    http://www.screenlight.tv
  • Kevin Williams
    October 28, 2010 at 8:12 pm
    thanks for the suggestions. i’ll let you know how things turn out.
    -kevin
  • Kevin Williams
    October 28, 2010 at 9:26 pm
    Richard,
    thanks for the suggestion. the file is much smaller now and still looks great for what I need. Thanks for helping out a newbie.
    -kevin williams
