Activity Forums Adobe After Effects compression for web
  • compression for web
    Posted by Rj Hannigan on April 18, 2005 at 11:59 pm
    trying to get my short film small enough to put on my site…its about 7 mins with some compositing in it…dont wan’t it to break up that much…i have final cut and cleaner 6…tried a sorenson 3 compression on medium on it looked great but was 99 megs…any advice on certian settings to get it small enough??thanks in advance
    Regards,
    R.J. Hannigan
    Steven L. gotz replied 21 years, 5 months ago 2 Members · 1 Reply
  • Steven L. gotz
    April 19, 2005 at 12:31 am
    You will probably want to make the frame size 320X240, and a data rate of around 512K, and you may find that you can cut the frame rate in half. That should be a start. You may find that 768K suits you better, but it does increase the size quite a bit.
