Activity › Forums › Apple Final Cut Pro Legacy › Compression for Web
  • Compression for Web
    Posted by Eric Klassen on July 10, 2006 at 6:49 am
    I’ve got a timeline at 4:45 long that needs to compress to under 10MB. I’ve tried H.264, but can’t get it to go that low without turning it into mush. If I want to keep the size at 320×240, how do I do this without turning into total garbage?
    Thanks in advance,
    Eric
    Bill Kelly replied 20 years, 2 months ago 2 Members · 1 Reply
  • Bill Kelly
    July 10, 2006 at 7:35 am
    The easiest, no fuss method is to export your timeline into one clip on to your hard drive. Open IMovie and import it into there. Drag it down to the IMovie timeline. Then go to File>>Export and it will give you a bunch of options (email, web, etc) where it will show you the size of the movie after it is compressed (320×240, 160×120, etc.) as well as the file size (8MB, 4.2 MB, and so on. This way you don’t have to worry about the compression settings when exporting from Final Cut because Final Cut doesn’t give you an expected size of the file.
    I don’t know how well an almost 5 minute clip will look at 320×240 at under 10MB, but this method is worth a shot. Good luck.
