Activity › Forums › VEGAS Pro › Compression for web
  • Compression for web
    Posted by Bernie Ageeb on September 20, 2012 at 10:54 am
    I have a project which is in HD and 10min long and i need to up load to the web(vimeo) for a client to look at. What is the best compression for High quality and keep it a small size? I am using Vegas Pro 11. Thanks
    Bernard
    John Rofrano replied 14 years ago 3 Members · 4 Replies
  • Roger Bansemer
    September 20, 2012 at 7:52 pm
    I use the Sony AVC/MVC template and then go to “custom” where I set the bit rate to 4,000,000. That works pretty good for me.
    Roger Bansemer
  • John Rofrano
    September 21, 2012 at 10:58 am
    [Bernie Ageeb] ” I am using Vegas Pro 11.”
    Roger’s advice is correct for version of Vegas Pro up to version 10.0. For Vegas Pro 11.0 Sony changed a bunch of things and one of them was the “Internet” render templates.
    For Vegas Pro 11.0 you should use MainConcept AVC/AAC (*.mp4) output format with either the Internet HD 720p or Internet HD 1080p template for sites like YouTube and Vimeo. These will give you the best output and render a whole lot faster than Sony AVC does if you have a good GPU graphics card.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bernie Ageeb
    September 21, 2012 at 8:26 pm
    Thanks guys. it worked
  • John Rofrano
    September 22, 2012 at 1:44 am
    You’re welcome. Glad it worked.
    ~jr
