Activity › Forums › Compression Techniques › Compression for streaming – I can’t figure out the settings the client wants.
  • Compression for streaming – I can’t figure out the settings the client wants.
    Posted by Sam Waldron on September 8, 2011 at 7:11 pm
    Hey CC members.
    I only just finished one post on Compression techniques, now I start another. Same client, same video.
    So I no longer have the original time FCP file. I have the video but no sound. There for I downloaded this https://www.vimeo.com/24415806 from vimeo. It comes as an MP4.
    So the client asked if they could have the file in the settings below:
    MP4 format
    H.264 compression, baseline coded
    Prepared for streaming
    AAC audio compression
    height: 400 pixel / width: proportionate
    height for webopener: 576 pixel / width: proportionate
    max. 10 MB
    Now I am not a complete beginner. But this may be a really dumb question. Can you produce a file with H.264 Codec in MP4 Format?
    I have tried and tried again but the quality of all the outputs are, well horrendous might describe it. I used the presets in Compressor and then tweaked them to get the settings above.
    Where am I going wrong. Is it the original file causing problems? The presets for streaming (I tried all to no avail)? Also I have no idea what webopener height is?
    Help would be appreciated.
    Kind Regards
    Sam
    Sam Waldron
    Final Cut Pro 6.0.6
    imac 4gb 1tb
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Ken Mitchell replied 15 years ago 3 Members · 3 Replies
  • Craig Seeman
    September 8, 2011 at 7:22 pm
    [Sam Waldron] “Can you produce a file with H.264 Codec in MP4 Format?”
    Yes with Quicktime 7 Pro.
    No with Compressor 3.x and below (although with iOS .m4v files you can change the extension to .mp4 since the essences are the same).
    Yes with Compressor 4.
    In most cases though H.264 .mov works in the same places and the same way H.264 .mp4 works such as Flash and Silverlight.
  • Sam Waldron
    September 9, 2011 at 8:09 am
    Hi again,
    thank you for the reply. I am currently downloading Compressor 4!!!
    Any ideas regarding quality and the ‘streaming’ presets in Compressor? Do you think the original file is a problem?
    Kind Regards
    Sam
    Sam Waldron
    Final Cut Pro 6.0.6
    imac 4gb 1tb
  • Ken Mitchell
    September 19, 2011 at 2:14 am
    I may be mistaken but the .mp4 codec which is probably what your client is inquiring about is H264. It is not a .mov quicktime.
