Activity Forums Compression Techniques compression for non standard movie files
  • compression for non standard movie files
    Posted by Jamil Yamani on June 20, 2008 at 4:28 am
    Hi all
    Is there anyone out there using a Mac and also authoring for non-standard frame sizes? it seems that the mpeg2 format has some limitations re frame size when exporting from compressor.
    what i mean is that if i had a file that was 1000 x 3000 pixels and i try to export to mpeg2 through compressor, then compressor would alter the pixel dimensions to 720 x 576
    is anyone using different software to accomplish this task, like cleaner or something i haven’t heard of?
    thanks
    jamil
    g5 intel multi etc
    The Electric Canvas
    Large Format Projection Specialists
    Sydney, Australia
    Daniel Low replied 18 years, 3 months ago 2 Members · 2 Replies
  • Daniel Low
    June 20, 2008 at 11:53 am
    It’s very unlikely that you’ll find a transcoder that will work to non-standard resolutions like that, but you can give this a try –
    https://www.digigami.com/megapeg/index.php
    Even if it does produce files to that resolution it’s even more unlikely that you’ll find anything that can play them back!
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Daniel Low
    June 20, 2008 at 12:04 pm
    If you’re producing files for OnlyView then I think you’re going about it the wrong way. Onlyview tiles images and video together to produce the huge and odd sizes they project.
    You should contact them to see exactly what they work with.
