Activity › Forums › Apple Final Cut Pro Legacy › Compression for Film Fest, and I’m in trouble now!
Posted by Geoff Mckay on November 27, 2012 at 7:50 pmHello All,
I am looking for some quick advice. I have a short film that is going to be projected on a large theater screen. I have edited in FCP, 1080p 30fps. I need to know a quick setting in compressor that will give me good quality. I don’t have time to download and learn any new programs. This sucker has to be ready in two hours and at this point I am stuck with compressor. The guy will be broadcasting of his laptop so he should have a lot of flexibility in format.
I used apple pro res high qaulity, and got a good product. I also got a 10 GIG file for a 6 minute vid.
Any other suggestions?Geoff
Rafael Amador replied 13 years, 10 months ago 5 Members · 8 Replies -
Mark Suszko
November 27, 2012 at 8:14 pmQuick, hire a new guy and blame this on him.
Playing off a laptop, Into what kind of projector system, is the question. Mpeg2 (DVD format) may be the most bullet-proof, but makes high def problematical. H.264 or MPEG4 is my go-to choice, but again, what kind of source does the projector take?
Geoff Mckay
November 27, 2012 at 8:20 pmHey,
Thanks a lot man. I’ll look into spreading out the blame. I tried H.264, and will go with it if I have to. It looks pretty bad though. Thanks for the tip on the MPEG 4. I am going to give that a try!! I guess I’ll just have to suffer through whatever happens, and not use those free tickets to the filmfest!! -
Nick Meyers
November 27, 2012 at 10:35 pmcheck the projection is of a mac laptop,
and has FCP installed
if it is:
export as native.if FCP is NOT installed
export as native
take you file and your QuickTime codecs, and put them in the other system.as dave says, say your prayers.
or, do YOU have a laptop with FCP installed?
take the file and the laptop.nick
Bryan Mailer
November 28, 2012 at 8:54 amHope things went okay. You can tell them that Brian Mailer did it and he has been fired.
Rafael Amador
November 28, 2012 at 10:16 amUnless you have Compressor. 4, don’t use Compressor to export an MP4. Compressor.2 y 3 uses an old fashioned MP4 (Isma profile) very little efficient.
[Geoff McKay] “I tried H.264, and will go with it if I have to. It looks pretty bad though. “
Probably you used the wrong settings.
The most universal solution (PC, Mac,..) is an MP4/H264.
Use MPGStreamclip.
– Select H264 as the compressor.
– Quality slide: All to the left.
– Limit data rate: 30.000 Kbps. Thats Bluray quality.
– Click B-frames and MULTIPASS.
– Frame size; 1920×1080 (unascaled).
– Deselect “Interlaced Scaling” if your movie is Progressive.
– Audio: AAC. 256 Kbps.
If you gonna play from a Mac, you can export a QT/H264 with exactly the same settings.
rafael -
Geoff Mckay
November 28, 2012 at 3:39 pmHey Guys,
Thanks for all the help!! I wound up exporting to quick time H.264 and reduced the quality to “good” instead of “best”. Seemed to put out an acceptable product. Here is a little tip, we have a computer PHD on our staff and he filled me in on why I was having so much trouble transferring huge files to stick or card. Anything over 4 gig, will usually have to be split up, or your memory stick or card won’t swallow it in one bite. My file is now 2.5 gigs and manageable. I really need to spend some time learning compression though. Maybe I’ll wait until two hours before the next film festival!!Thanks,
Geoff
Geoff Mckay
November 29, 2012 at 6:16 pmHello Guys,
Just wanted to let you know how things turned out. I was able to put a reasonable file together, but they didn’t receive it in time, so the low res version went up on the screen. You can imagine my feelings when I (and the entire audience) saw all my footage appear as if it was shot on a cell phone.
I tried to follow the advice of sharing the blame, but it was tough to find a scapegoat in my one man operation. Oh well, live and learn I guess!!Once again, thanks for the help!!
Geoff
Rafael Amador
November 30, 2012 at 9:20 am[Geoff McKay] “Anything over 4 gig, will usually have to be split up, or your memory stick or card won’t swallow it in one bite.”
Yes.
that is the big shortcoming of the FAT-32 format.[Geoff McKay] ” I was able to put a reasonable file together, but they didn’t receive it in time, so the low res version went up on the screen.”
Don’t worry. Next time you’ll get it right from the beginning.
rafael
