Activity Forums Apple Final Cut Pro Legacy compression for dvd duplication
  • compression for dvd duplication
    Posted by Oliver Lynch on November 28, 2007 at 7:06 pm
    I have just finished a project 45mins long.
    What is the best way to compress the project to get the most out
    of it.
    I usually just drop an uncompressed export into dvd studio pro for compression but this project is for larger distrabution and would like to get the best quality possible ?
    Bear Media replied 18 years, 9 months ago 4 Members · 10 Replies
  • 10 Replies
  • Brigitta Boccoli
    November 28, 2007 at 7:28 pm
    I believe you are using Apple products.
    In this case your best bet is Apple Compressor,
    it has different preset of mpeg2 (DVD) compression, and since you have a 45 mins project you should look for a
    “best dvd encoding 90mins” from your preset window.
    Once Compressor has generated the file, you can easily import it in dvd studio pro.
  • Mark Maness
    November 28, 2007 at 8:03 pm
    Using the compression that was spoke of will only fill half of your disc. I would suggest playing around with your bitrates but don’t go over 8 mbits. The higher the bitrate, the better the quality.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Brigitta Boccoli
    November 28, 2007 at 8:08 pm
    Some dvd players (desktop dvd players) wont read a 7mbits file… I am talking about the cheap ones that you buy for 30$, and most people have that.
  • Mark Maness
    November 28, 2007 at 8:47 pm
    Really…
    We have a cheap ole Wal-Mart special, the Apex that’s about 7 years old and it reads my 7 mbit disks with no problem.
    7 mbit is about the maximum you really should go.
    Wayne Carey
    Schazam Productions
  • Oliver Lynch
    November 28, 2007 at 9:15 pm
    thank you
    I will try a few things with compressor.
  • Bear Media
    November 29, 2007 at 7:11 am
    I’ve switched over from Compressor to Bit Vise Mpeg2 encoder. I had to find something that handled dissolves and text well, and I’ve been blown away. I ran into a situation that required a quick turn around on compressing two feature length docs (90 mins each) without the budget to go to a compression house. The quality has exceeded my expectations on every front.
    You may want to check into it. Google BitVise encoder, and try out the demo.
    Hope this helps.
  • Brigitta Boccoli
    November 29, 2007 at 7:16 pm
    It sounds cool.
    Do you compress directly from HDV, or you export first the footage in a different format?
  • Bear Media
    December 1, 2007 at 5:28 am
    I actually compressed an HD quicktime reference file last night. The project was only 6 minutes long, but BitVise does the scale down so you don’t have to output any intermediate file before hand. The result was stunning as usual. Transitions, solid colors, gradients, and Text were all crisp and clean. I’m blown away by the quality that encoder puts out.
    I’ve never been all that happy with any jobs I’ve had to output with compressor.
  • Brigitta Boccoli
    December 1, 2007 at 6:36 am
    It sounds interesting.
    How does the demo come?
    Any watermark or aliens in the background?
  • Bear Media
    December 1, 2007 at 6:45 am
    Yeah. The demo has a rather crude watermark in the center of the image, but you can still get a good idea of how the compression will look on a project.
