Activity Forums Compression Techniques Compression for Cartoon DVD
  • Compression for Cartoon DVD
    Posted by Trent Diggity on October 6, 2009 at 8:01 pm
    I’ve just finished up work on a 4 minute cartoon that was completed in Flash/After Effects. I’m running into problems when compressing it to dvd. I’ve tried using dvdstudiopro and allowing it to handle the compression and the results are pretty bad. I then swapped to compressor and they have improved but still arnt anywhere near the quality of a dvd one would purchase over the counter. Anyone have an idea on how I can improve my image quality? there are alot of flat colors and after compression they end up with artifacts.
    Thanks.
    -Trent
    Daniel Low replied 16 years, 11 months ago 3 Members · 12 Replies
  • 12 Replies
  • Daniel Low
    October 6, 2009 at 9:02 pm
    Try changing the settings.
    Seriously, if you can’t tell us what you have already tried in terms of encoding settings, how are we going to be able to give any useful advice?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
    “We and Apple are neck and neck and we’re chasing the two
    other players,” Ballmer said, referring to Nokia and Research in Motion. October 6th 2009
  • Trent Diggity
    October 7, 2009 at 3:23 am
    So far I’ve tried
    DVDStudio Pro’s compression, I dont think settings can be altered on this but I could be wrong
    Adobe Encore – same deal.
    After getting bad results I took my movie into compressor.
    From here I tried these two defaults
    120 Min DVD Best Quality 2 passes
    90 Min DVD Best Quality 2 passes
    when that failed to give desired results, I upped the mb/sec to 7.7
  • Daniel Low
    October 7, 2009 at 8:36 am
    You can change the settings in DVD SP – check the preferences.
    Please tell us about your source content:
    What’s the frame size and frame rate?
    What format/Codec did you use to export it from AfterEffects?
    Steve Ballmer To USA Today: 30 April 2007
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • Trent Diggity
    October 7, 2009 at 5:12 pm
    Source content is 30fps, 720×486. Animation compression out of after effects. I’ve viewed it on a professional monitor and scope, It looks perfect before going down to mpeg2. In the encoder section of compressor, I’ve pushed the quality as high as it will go – 7.7mbs.
  • Daniel Low
    October 7, 2009 at 6:01 pm
    [Trent Diggity] “Source content is 30fps, 720×486. Animation compression out of after effects”
    It looks like you made one very common error, you’ve rendered out a square pixel project to a non-aquare pixel frame size and this will be degrading the picture quality some what. You should have rendered out at 640×480 Square pixel
    Additionally, are you using CBR or VBR, 1 pass or 2 pass in compressor?
    other players,”
  • Craig Seeman
    October 7, 2009 at 6:16 pm
    I’ve had some personal bad experience with Animation codec files as source. Sometimes exporting out of After Effects in 8 bit Uncompressed will hold up better going to MPEG-2. I can’t say that’s the issue with a certitude but it’s another think to try in addition to Daniel’s observation.
  • Trent Diggity
    October 7, 2009 at 6:39 pm
    I’m using VBR. I’ll give the square 640×480 a try now. I’ll let you know the results.
  • Daniel Low
    October 7, 2009 at 7:17 pm
    I’d also try CBR while you’re at it.
    other players,”
  • Trent Diggity
    October 9, 2009 at 6:24 pm
    So I tried going to the 640×480 square pixel. it actually made the problem a bit worse.
    I haven’t found where I can change to CBR, wheres that located?
  • Daniel Low
    October 9, 2009 at 6:39 pm
    In the same tab you change the bitrate, in the inspector
    other players,”
