Activity Forums Compression Techniques Compression for broadcast – am I doing this right?
  • Compression for broadcast – am I doing this right?
    Posted by Dylan Hargreaves on September 19, 2011 at 10:28 pm
    Hi folks,
    A documentary we produced has been picked up for broadcast, which is my first foray into TV since I quit that industry 4 years ago to set up my little web video business.
    We shot at full 1920×1080 HD, but the broadcaster is asking for 720×576 full height anamorphic. For the pixel aspect ratio I’m selecting PAL CCIR 601 (16:9).
    The resulting export is contained in a 4:3 box with no letterboxing and the picture ‘stretched’ vertically. Does this mean the broadcaster will then ‘correct’ the image for transmission or am I doing something wrong?
    Cheers in advance!
    Dylan Hargreaves replied 15 years ago 2 Members · 3 Replies
  • Craig Seeman
    September 19, 2011 at 10:39 pm
    Did they give you any codec information?
    What player are you using to play the file?
  • Dylan Hargreaves
    September 20, 2011 at 8:57 am
    Hi Craig,
    ProRes422, DV-PAL, 8bit uncompressed or 10 bit uncompressed are all acceptable. I’ve tried ProRes so far and used QT7 to view the output.
  • Dylan Hargreaves
    September 20, 2011 at 10:30 am
    Compressing in DV-PAL anamorphic has done it – now displays in the proper aspect ratio.
    Not sure what the pixel resolution would be if I did want to use ProRes though…
    Thanks anyway!
