Compression, Dropped frames Vimeo.
I am having a lot of trouble compressing my snowboard movie. It looks fine in VLC, but once it gets to Vimeo the frames drop. I have uploaded 4 different versions today, all with dropped frames, I will now list my specs, as well as a link to the video with dropped frames.
https://vimeo.com/20686226
Password: snowShot on Canon 7D at 60fps. Some shot’s edited in AE using Timewarp and then brought back into Final Cut. Can’t remember if I edited the shots as Prores422 or .Mov. I think it might be a mix of both.
Exported as Quicktime Movie
Compressed with either MPEG Streamclip or Final Cut Compressor.
Here are the formats I have tried, all get dropped frames once in Vimeo.
Compressor: File Extension: mov
Estimated size: unknown
Audio Encoder
AAC, Stereo (L R), 44.100 kHz
Video Encoder
Format: QT
Width: 1280
Height: 720
Pixel aspect ratio: Square
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls On:
Retiming: (Fast) Nearest Frame
Resize Filter: Linear Filter
Deinterlace Filter: Fast (Line Averaging)
Adaptive Details: On
Antialias: 0
Detail Level: 0
Field Output: Same as Source
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 24
Spatial quality: 79
Min. Spatial quality: 50
Key frame interval: 30
Temporal quality: 50
Min. temporal quality: 50
Hinted for QuickTime
streaming serverAnd when using MPEG Streamclip: Export to Quicktime, quality 100%, Audio 44.1, 1080×720 Unscalled, deinterlaced, and fast start.
Please Help.
