Activity Forums Compression Techniques Compression Confusion – 1080p to 720p
  • Compression Confusion – 1080p to 720p
    Posted by Eric Holzapfel on March 6, 2012 at 9:15 pm
    Hello All,
    I have been looking all over the forum, and have not quite found out
    a way to do this, or at least a way that works.
    I have some video that I shot with an HVX200 – format 720p30 (native frame size – 960×720)
    and some video shot with a Canon 5D – 1920×1080. I need to edit both of these video formats
    in the same timeline (oops I forgot to switch the Canon to 30 fps!).
    My initial thought was to convert the Canon footage to Apple ProRes using Grinder, and
    then use Apple Compressor to down-convert the footage to 720p with same frame dimensions
    as DVCPRO HD – compressor did not change the frame size – it remains at 1080.
    I also created a proxy using grinder (1280×720), and just overrode FCP message about matching the
    sequence to the clip settings.
    What is a better way – or at least a workflow for this? I do not have a capture card, AJA, Matrox, etc.
    Eric
    Charybdis and Scylla Productions
    Equipment – Using FCP 7 along with FCS 2 – Compressor 4
    Mac OS Lion
    Mac Pro workstation dual 2.8 with 16GB memory
    Final Cut Pro, Adobe After Effects, Photoshop
    Russ Haskell replied 14 years, 5 months ago 2 Members · 3 Replies
  • Russ Haskell
    March 7, 2012 at 1:07 pm
    You’re right that you should be converting the Canon’s h.264 files to Pro Res for editing. The preferred way to do this is via Log & Transfer within FCP. There is a helpful tapeless workflow tutorial by Shane Ross, which should come up from a search of these boards. If you don’t have the original intact card structure, Compressor can certainly do the Pro Res transcode, but it’s not very fast. In situations like that, I tend to use MPEG Streamclip which is faster.
    Compressor should do a pretty good jogb scaling the 1080 clips to 720. Go into the frames controls tab and set scaling to Best. How did you try to resize…in the Geometry tab?
    Russ
  • Eric Holzapfel
    March 9, 2012 at 1:16 am
    Hello Russ,
    It is nice I am on the right track. I did see the FCP log and transfer info by Shane Ross (Creative Cow, thank you very much!).
    Using Compressor 4
    I selected the DVCPRO HD codec, 720p60/30/24.
    My geometry settings are: 960×720 “Custom (16×9)
    I had the frames control set to :
    Resize Filter: Better (Linear Filter)
    Output fields: “Same as Source”
    Deinterlace: Better (motion adaptive)
    Rate conversion: Better (Motion compensated)
    Should I set the rate conversion to “Best”?
    Thank you for the information
    Eric
    eholz1
  • Russ Haskell
    March 9, 2012 at 2:59 am
    IMO, setting the resize setting to Best is a reasonable choice and shouldn’t bog down the process. It didn’t register with me that you were also changing frame rate; Better is probably fine. Too many Best settings combined could produce extraordinary processing times.
    Russ
