Compression app suggestions
Ok, this one is for the veterans out there. I think most encoding software is pretty rudimentary if you ask me. Here are a couple things I would like to see.
Clip analyzer – Especially for MPEG-2. A faster than realtime analyzer that runs through the clip and shows a graph of the bitrates, gives average, peak, low etc. Also can measure audio and video separately. This should work for many codecs.
A muxer should be part of every encoder.
An encoder should allow for every legal frame size for a given codec…compressor can’t do odd size MPEG-1 but cleaner and the rest can.
Video and audio settings on the same settings pallette. I don’t know why I have to specify a different audio setting in compresor. I like the cleaner model of tabs with every available option as part of the preset. Not a separate preset for your audio and one for video. I actually prefer the FCP A/V settings window with video on the top and audio on the bottom…similar to AE’s output module setting window. Uncheck audio if you don’t want it etc. This is an interface I can understand and work with.
I always like the left right frame shot with a slider to wipe between before and after frames. As you adjust various settings you would see the right side adjust.
Somehow build in a realtime encoding option via firewire for certain codecs that really want a two-pass…on the first pass it also uploads the clip while it analyzes and makes keyframes for tough areas. The second pass would read off the disc the cached file and do the encode.
If MPEG-Streamclip can do a pretty good job with their transcoder (it has a muxer too) for free, then imagine what the sorenson or Discreet guys could do with some money.
What else would you guys like to see in your encoding software.
Rich Rubasch
Tilt Media
