Activity › Forums › Compression Techniques › Compression and working with 4K xavc files
  • Compression and working with 4K xavc files
    Posted by Darren Rice on February 1, 2015 at 8:02 pm
    So i just upgraded from my 5D mK3 to a sony pxw z100 and have started to work with the XAVC files I have tried Native and optonized media, and using a 4K timeline vs a 1080P timeline and then outputing master files in prores vs h264 files.
    My ultimate goal is getting video’s to youtube and vimeo in as smaller package as possible but still looking good and so far I am failing, mainly because i live on a small island in the south pacific and my internet speed is close to dial up so uploading large files is out of the question.
    So im guessing you feel my pain?
    just looking for some advice on workflow and output compression settings
    here is the one test video I have done so far https://vimeo.com/118382031
    the uncompressed 10 bit file for this 64 sec piece was close to 100 GIG
    the h264 I eventually outputted was 75 meg
    I also understand most people dont have the ability to view true 4K yet
    But after working on this last test project and seeing the quality of my files on my non 5K iMac then seeing the finished product on vimeo it was a big dissapointment
    To upload a 1gig file will take me 24 hours but im happy to do it, alternatively i can give files to people to take home and upload them for me .
    Would just appreciate any help you guys here on the forum can give me
    Darren Rice
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jane Kong replied 11 years, 5 months ago 3 Members · 3 Replies
  • Craig Seeman
    February 1, 2015 at 10:51 pm
    For best quality follow YouTube’s recommendations.
    https://support.google.com/youtube/answer/1722171?hl=en
    For best quality H.264 encoding use an x264 encoder rather than MainConcept.
    If using Apple use High Profile, CABAC entropy single pass encoding.
  • Darren Rice
    February 2, 2015 at 6:20 am
    Craig much apreciated I ran the file back through compressor I found some of the settings mentioned and i ended up with a 115mb file that is far superior to the 75mb one I had origonally thanks so much for your help
    Darren
  • Jane Kong
    April 26, 2015 at 8:32 am
    It seems that you already solved your problem, but still if you don’t mind I post here.
    For the 4K, that YouTube may not support very well, for the playback may be jerky. Also the XAVC format is not friendly to YOuTube. You can edit your files in FCP or other editing software before uploading to YouTube.
