Activity › Forums › Adobe After Effects › compression
  • compression
    Posted by Rory Kelly on June 21, 2010 at 9:41 am
    i have a comp that, when rendered is about 33 gig. i would like to get this down to fit on a DVD so around 4 gig. what would be the best compressor to do this?
    thank you.
    Walter Soyka replied 16 years, 3 months ago 3 Members · 2 Replies
  • Kevin Camp
    June 21, 2010 at 3:09 pm
    are you talking about burning a data dvd, or a dvd that is playable in a dvd player (or a computer with a media player)?
    if you want a dvd that is playable in a dvd player, many dvd authoring apps will convert the media to dvd standard mpeg-2 and burn it. unless your media is longer than 2 hours, i doubt you’d have any problems fitting it onto a dvd.
    if you want a data dvd, then you should try a compression utility to compress you file (you might try adobe’s media encoder, it should have come with ae8 and up).
    mpeg-2 or h.264 should get you good quality for the data rate, but you’ll also want to think about the container… i think i’d try a .mp4 with h.246, rather than, say a .mov with h.246. the .mp4 should open in players other than quicktime… same for a .wmv, which would need win media player or a qt plugin.
    of course if you know that the machine the disc will be taken to has qt or wmp, then container will not be a problem.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Walter Soyka
    June 21, 2010 at 4:21 pm
    What is your intended delivery? Are there specific requirements on format, resolution, and codec?
    Walter Soyka
