Activity Forums Panasonic Cameras Compression
  • Compression
    Posted by Andrew Hampy on June 16, 2006 at 2:31 am
    When shooting with the DVX100 to mini DV tape, Is there any compression of image from what the camera processes to what goes on the tape or is this uncompressed. I know that compression happens when you digitize to a computer but is there any compression from camera image to the mini dv tape. Thanks
    Marco Solorio replied 20 years, 2 months ago 3 Members · 2 Replies
  • Noah Kadner
    June 16, 2006 at 4:21 pm
    Of course- there is DV compression. That’s what all DV cameras use. There is no additional compression when you capture to computer, provided you are going via Firewire you are getting a 1:1 digital clone of what’s on the tape. You add additional compression whenever you add anything in post- like a transition, color correction, title, etc. Here are the specs for DV:
    https://www.dvcollections.com/support_dvcompress.html
    Noah
  • Marco Solorio
    June 22, 2006 at 5:25 am
    Noah hit it spot-on. Just to add… the image sensors on the camera do create a beautiful uncompressed 4:2:2 image. If you take the live feed out of the camera (like S-Video), it’ll give you an amazing shot that is superior to what you get on DV tape (if you don’t mind the chrominance channels being smushed together). Some people will take a live feed for chroma-keying and capture it direct to disk. Doing that with the likes of an SDX-900 and using its SDI output will give you full 10-bit uncompressed 4:2:2 video. Delicious.
    Death to tape. Cheers for P2 technology.
    Marco Solorio  |  OneRiver Media
