Activity › Forums › Compression Techniques › compression
  • Posted by Ed Vandenderen on February 22, 2009 at 10:48 pm
    gentlemen
    I have a 2 hour project(according to the track time code) in vegas.
    This would be as yet .avi format.
    I hear that 2 hours of video will fit on a 4.7 g disc. Yet if I take say 590 and divide it by 120 min, I get an average BR of 4.9 megabits.
    Is this not quite low and will the clarity suffer at such a low rate?
    thanks
    Daniel Low replied 17 years, 7 months ago 2 Members · 3 Replies
  • Daniel Low
    February 22, 2009 at 11:45 pm
    It’s not low at all. I’ve seen major Hollywood titles drop lower than 1.8Mb/s.
    FYI, transmission (TV) MPEG-2 is in the region of 2.2-2.7Mb/s at the very best, most often much lower.
    It all depends on the quality of your source, the quality of your encoder and your skill.
    p.s. Don’t forget the audio – use AC3 rather than PCM to save space
    Fonts are like cologne:
    A bad choice speaks louder than a good one.
  • Ed Vandenderen
    February 23, 2009 at 1:37 am
    Dan
    Would you go any lower than this to get a larger file onto a single disc? How much lower? I several large movies to compress.
    I assume 2 pass vbr would help with larger files.
    Well, thanks for being around on a Sunday and for the help.
  • Daniel Low
    February 23, 2009 at 7:56 am
    It really depends on the job, the client and the quality of the source, but ultimately what sort of quality are YOU prepared to drop to..
    2-pass VBR is certainly the way to go.
