  • Posted by Alex Martinez on May 9, 2011 at 7:57 pm
    I have a 35 min video that i recorded with my canon 60d… I finished the editing in final cut… Now i want to export it to a dvd in high definition ..I started compression at 11:00pm last night and its still compreesing ( its been over 12 hours) .. Is this “normal”… The codec i used for compression was H.264 10.Mbps…Can anyone please assist me …. Thanks in advance.
    David Roth weiss replied 15 years, 4 months ago 4 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    May 9, 2011 at 8:41 pm
    Well, the only DVD format that is HD compatible is BluRay. The “HD DVD” format lost that battle. Yet, there are still those settings in Compressor. Only Toshiba HD DVD players, and Macs, play back HD DVDs.
    How long was your project?
    To encode to BluRay, you will need a BluRay drive, and you can use SHARE from FCP…or you need something like Toast 10.
    Shane
  • Alex Martinez
    May 9, 2011 at 8:45 pm
    THANKS SO MUCH FOR RESPONDING.. MY PROJECT IS 35 MIN. LONG.. I WANT TO ENCODE TO A REGULAR DVD-R. IS IT NORMAL THAT IT TAKES THIS LONG ??? THANKS AGAIN
  • Shane Ross
    May 9, 2011 at 9:05 pm
    To encode a regular DVD, you use one of the DVD HIGH QUALITY or FAST ENCODE presets. Take that long? It might. Did you render everything first, then SEND TO COMPRESSOR? Or not render before you did that? What EXACT steps did you take to get from FCP to Compressor.
    Typically what I do is Render, export a QT movie, REFERENCE quicktime, meaning I don’t check the SELF CONTAINED box. Then I take that into Compressor, choose the preset, and then hit SUBMIT.
    Shane
  • Alex Martinez
    May 9, 2011 at 9:09 pm
    THANKS AGAIN YOUR GREAT HELP… WHAT I DID WAS FIRST WAS IMORT THE FOOTAGE STRAIGT FROM THE CAMERA, EDIT IT, RENDERED EVERYTHNING, THEN EXPORT TO COMPRESSOR SET THE CODEC I MENTIONED EARLIER,SET THE DESTINATION , AND THEN SUBMIT…
    FEEL FREE TO LET ME KNOW IF I DID ANYTHING WRONG…
  • Shane Ross
    May 9, 2011 at 10:18 pm
    You didn’t convert to an editing codec. You have a processor intensive shooting and delivery codec (H.264) that can be a toll on computer processors. You must convert Canon footage to an editing format before editing. I have a tutorial on that here: Tapeless Workflow for FCP 7 Tutorial
    What to do now? Let it finish. Stopping now means wasted time. Unless it keeps going and taking forever. Then I’d export a self contained movie…try again. Shouldn’t take that long really.
    Shane
  • Chris Tompkins
    May 9, 2011 at 10:36 pm
    Compressing from HD material to a SD DVD can take a long time on older machines.
    I have seen 15 hour renders doing this.
    Chris Tompkins
    Video Atlanta LLC
  • Alex Martinez
    May 9, 2011 at 10:45 pm
    THANKS AGAIN … WHAT DOES EXPORTING A SELF CONTAINED MOVIE DO ??
    ALSO, IM WATCHING YOUR TUTORIAL, VERY INFORMATIVE ..
  • David Roth weiss
    [Chris Tompkins] “Compressing from HD material to a SD DVD can take a long time on older machines.
    I have seen 15 hour renders doing this.”
    Especially if you do it right from the timeline. Exporting a self contained file takes just a minute and will save you hours of compression time.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • David Roth weiss
    May 9, 2011 at 10:54 pm
    [alex martinez] “WHAT DOES EXPORTING A SELF CONTAINED MOVIE DO ??”
    Please, use of all caps is forbidden here on the Cow and throughout the known universe.
    A self contained file is an exact duplicate of your timeline in a single QT file without losing a generation. To do it you go to Export>>QT Movie and do not check re-render all frames and do check make self contained.
    David Roth Weiss
    Los Angeles
  • Chris Tompkins
    May 10, 2011 at 12:19 pm
    Self-contained or Ref file make no dif.
    After exported file, drop that file into Episode or Compressor or your compression software fo choice to create the SD DVD files – this can take hours to compress @ high-quality settings.
    Chris Tompkins
    Video Atlanta LLC
