Activity › Forums › Apple Final Cut Pro Legacy › Compression
Compression
Posted by Simcha Leiner on August 19, 2007 at 3:36 amI Just exported a 45 min production as a quicktime file coming out to be 9 gig what would be the recommended way to get it down to about 3-3.5 gig
ThanksFS Studios
Simcha Leiner replied 19 years, 1 month ago 2 Members · 4 Replies -
Tom Wolsky
August 19, 2007 at 3:40 amNo good answer without knowing why you what to get it down to that size. Where are you going with this? Where are you trying to get to?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Simcha Leiner
August 19, 2007 at 3:45 amPlan on putting it as main feature on a dvd which must include an additional 1-1.5 gig
Thanks -
Tom Wolsky
August 19, 2007 at 4:14 amIf you’re making a DVD (not a data DVD) then you have to encode it to MPEG-2. Should be able to fit 45 minutes with plenty of room to spare. Use Compressor and try the 90 minute best. The front panel will tell you about how big the file will be.
All the best,
Tom
