Activity Forums Adobe Encore DVD Compressing video authoring to fit on Single Layer DVD
  • Compressing video authoring to fit on Single Layer DVD
    Posted by Brent Dunn on August 19, 2011 at 4:45 pm
    Is there a way to compress the video more in Encore so it will fit a single layer DVD? I can’t find any adjustments in the preferences or settings.
    Right now I’m using Encore CS4 on a Mac. I have 1 hr & 40 minutes of HD ProRes edited footage. Encore will only compress it down to 5.6 Gig’s, so I have to use a Dual Layer DVD. I have a client that requested it be put onto a single layer DVD. I have 4 pages of basice menu’s.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
    Minu Sharma replied 14 years, 12 months ago 3 Members · 4 Replies
  • Ricky Barrow
    August 19, 2011 at 5:30 pm
    Adjust your transcode settings to custom or change to a different preset. For 1 hr. 40 min. with no ROM Content here are the settings to maximize quality:
    100 min. PCM audio with 5% headroom = 4.4 Mbps
    100 min. AC-3 audio with 5% headroom = 5.7 Mbps
    100 min. PCM audio with 10% headroom = 4.1 Mbps
    100 min. AC-3 audio with 10% headroom = 5.4 Mbps
    Hope this helps – on PC, right click file to “Transcode Settings” and if you want to customize, go to “Edit Quality Presets”
    Ricky
  • Brent Dunn
    August 19, 2011 at 6:19 pm
    I’m on a Mac. Where in the Menu can I change the transcode settings?
    Brent Dunn
    DunnRight Films
    DunnRight Video.com
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    HP i7 Quad laptop
  • Ricky Barrow
    August 19, 2011 at 6:42 pm
    Sorry – I don’t know on MAC – the help menu will take you straight there though.
    Ricky
  • Minu Sharma
    September 5, 2011 at 11:46 am
    Hi Brent ,
    You can do the following :
    1. Go to File>Edit Quality Presets ..
    2. Make changes in settings and save preset with a name.
    3. Click ok.
    4. Now from project panel , select asset right click and choose Transcode settings.
    5. From DVD Transcoding dropdown choose the preset you created.
    6. Click ok.
    7. Do the same for all assets( if you have more)
    8. Now go to build and check disc info. If it says the data is less than 4.7GB , it will fit in single layer.
    Minu
