Activity › Forums › Compression Techniques › Compressing Tons of Video
  • Compressing Tons of Video
    Posted by Jonathan Jirjis on April 4, 2013 at 2:31 pm
    Hello,
    So I have many (a few thousand) video files (mov & MP4) that I need to convert to H.264 .mov files in a few resolutions. I need to export them at 1080p, 720p and one other lower resolution. I also need to be able to add a bug in the bottom right hand corner of the frame and limit bitrate & add fast streaming (quick start).
    What software do you recommend I use? I’ve used compressor but it has some serious issues holding up when I throw that many files at it. Even if I compress in smaller batches of 50. I need something that I can send a good amount of files at.
    Craig Seeman replied 13 years, 6 months ago 2 Members · 5 Replies
  • Craig Seeman
    April 4, 2013 at 2:46 pm
    Telestream Episode. You may want to consider Episode Pro or even Episode Engine. I’d get the x264 codec with it as well for best quality/file efficiency.
    https://www.telestream.net/episode/overview.htm
  • Jonathan Jirjis
    April 4, 2013 at 2:53 pm
    Is that my only other option? What about Sorenson Squeeze or DV kitchen?
  • Craig Seeman
    April 4, 2013 at 2:58 pm
    Squeeze would work as well but I’m not sure it has the clustering features if you want to go that route. Otherwise it could work.
  • Jonathan Jirjis
    April 4, 2013 at 2:59 pm
    Can you tell me a little bit more about clustering please? So I have a clear definition.
    Thank you.
  • Craig Seeman
    April 4, 2013 at 3:05 pm
    If you have a lot of files (as you do) you can link several machines together to use all the cores available to speed encoding.
    If you scroll up a bit on this page you’ll see a brief description.
    https://www.telestream.net/episode/features.htm#speed
