Activity Forums Compression Techniques Compressing to MP4 without losing multitrack audio
  • Compressing to MP4 without losing multitrack audio
    Posted by Stephen Ratkovich on March 21, 2019 at 2:12 pm
    I have source MP4 files that have 3 distinct audio tracks.
    Track 0 = H264, AVC1, 709 color
    Track 1 = track 2 and 3 mixed together, AAC, 16 kHz, 32 bps
    Track 2 = audio from mic 1, AAC, 16 kHz, 32 bps
    Track 3 = audio from mic 2, AAC, 16 kHz, 32 bps
    If you open up one of the source files in VLC or QuickTime 7 Pro, you can see in the media info/movie properties that track 1 plays by default in both the left and right channels.
    You can then select which track to listen to (solo).
    I want to trim these MP4s and then export with settings as close to the source as possible.
    I’ve tried exporting through QT7Pro, Compressor, and Adobe Premiere Pro/Media Encoder and the resulting file always loses the multitrack, which I’m guessing either means track 2 and 3 are ignored or mixed down.
    I’ve tried the following to no avail:
    https://forums.creativecow.net/thread/3/972763
    https://revuptech.com/content/blog-guest-/exporting-multichannel-quicktimes-in-premiere-pro-45
    • setting track 1 to center, track 2 to left, track 3 to right in CLR
    • setting each of the tracks in Compressor as mono; 1 discrete channel; discrete-0, discrete-1, discrete-2; mono, 1 discrete channel (t2 & t3)
    I will not contact the originator of the source files for… reasons.
    I can see there is promise in choosing uncompressed audio with a QuickTime/MOV codec/wrapper, but would like to avoid it if possible.
    What can I do to just save a trimmed version of the source in its native settings without losing the multitrack audio?
    Michael Mcintyre replied 7 years, 4 months ago 3 Members · 2 Replies
  • Craig Seeman
    March 21, 2019 at 3:25 pm
    You might be able to trim them in Telestream Switch
    Otherwise, I assume any good NLE will do this but perhaps Media Encoder doesn’t handle it?
  • Michael Mcintyre
    March 21, 2019 at 7:17 pm
    Another vote for Telestream Switch. I had similar needs for keeping audio tracks intact and it is great. While you won’t be able to set up a batch of multiple files, it’ll definitely pass-through the audio and trimming is also an option.
