Activity Forums Compression Techniques Compressing to create HI QUALITY DVDs Question –
  • Compressing to create HI QUALITY DVDs Question –
    Posted by Natasha O’cconor on July 23, 2008 at 3:55 am
    I have read many many many threads related to this subject over the last few weeks. I am yet to find something that will help me even more…
    FACTS-
    I create DVDs for work with 16×9 hi-res material. Each piece of material is between 30-60sec long. I go from Compressor 3.0.3 then create the DVD in DVD Studio Pro 4.
    With the material calculated in time, there is no more than 30min. I am using the 90min hi quality compressor DVD preset.
    The material is not coming out great, it is ok but I need to try and make it better. Once I have gone through the process of actually making the DVD in Studio Pro the quality of the vision is standard. I need to try and make HIGH quality material not just standard.
    Compressor settings I’m using –
    Description: SETTINGS FOR DVD (90MIN)
    File Extension: m2v
    Estimated file size: 3.03 GB/hour of source
    Type: MPEG-2 video elementary stream
    Usage: SD DVD
    Video Encoder
    Format: M2V
    Width: 720
    Height: 576
    Pixel aspect ratio: PAL CCIR 601 (16:9)
    Crop: None
    Padding: None
    Frame rate: 25
    Frame Controls: Automatically selected: Off
    Start timecode from source
    Aspect ratio: 16:9
    Field dominance: Automatic
    Average data rate: 6.9 (Mbps)
    2 Pass VBR enabled
    Maximum data rate: 8.3 (Mbps)
    Better motion estimation
    Closed GOP Size: 12, Structure: IBBP
    DVD Studio Pro meta-data enabled
    DVD Studio Pro settings I’m using –
    MPEG-2 SD
    Aspect Ratio: 16:9
    Field Order: Top
    Mode: Two Pass VBR
    Bit Rate: 7.1
    Max Bit Rate: 8.3
    Motion Estimation: Better
    Method: Encode on Build
    If you need me to supply further info just ask, more than happy to. So want to get to the bottom of this!
    Thank you,
    N
    Daniel Low replied 18 years, 2 months ago 2 Members · 1 Reply
  • Daniel Low
    July 23, 2008 at 10:29 am
    Can you tell me/us exactly what this “Hi-res” material is. I.E. how was it shot or generated? What format is it in? Frame size etc, as much information on the source material as possible please.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
