Activity Forums Compression Techniques Compressing the cmpression
  • Compressing the cmpression
    Posted by Terry Flaxton on June 26, 2017 at 1:13 pm
    I need upload a high quality H264 or Mp4 of a quicktime pro res file. The high quality is about high detail and many dissolves happening. So I have an 11 gig file that I need get to under 5 gig and I simply went into quicktime conversion and output an H264 file which came in at 23 gig.
    So I tried various things – direct FCP studio output – send to compressor etc and if I keep the quality high, I just get big files (apart from using a compressed file from pro res) what am I doing wrong and what can I do to get a reasonable 5 gig file?
    Would it be worth changing the pro res into something else to start from?
    A long term DP – likes 35mm and HD equally – changing with digital media – Began as a commercials editor !
    Terry Flaxton replied 9 years, 3 months ago 3 Members · 6 Replies
  • Lawrence Eaton
    June 26, 2017 at 3:49 pm
    Terry,
    my workflow is to:
    1) output from FCPX as prores 422HQ
    2) bring it into Compressor and use the Apple Devices>Apple Devices HD(Best Quality)
    3) encode
    4) change extension (if needed) from .m4v to .mp4
    Initial file size: 3.22gigs
    Final version: 120megs
    Dimensions: 1280 × 720
    Codec: AAC, H.264
    It’s all about your settings though, especially your bit rate, IMHO.
    Lawrence
  • Craig Seeman
    June 26, 2017 at 4:40 pm
    It’s very important and very basic math to understand compression and file size. Mostly math one might learn in middle school (junior high school).
    File Size = duration x data rate.
    Changing the data rate changes the size.
  • Terry Flaxton
    June 26, 2017 at 5:11 pm
    That’s close to what I did but s I say got 23 gig from an 11 gig file. As to the next post – yes of course – normally simple maths, but I got different.
  • Terry Flaxton
    June 26, 2017 at 5:13 pm
    That was my point really – I’ve been doing this since 1976 – from analog forward. But this time I got 23 gig from 11. So I wondered at that – are there any people out there that had this kind of anomaly?
  • Lawrence Eaton
    June 26, 2017 at 10:07 pm
    Terry,
    Maybe something corrupted in your project?
    Have you tried copy/pasting into a new project and trying again?
    Lawrence
  • Terry Flaxton
    June 27, 2017 at 8:31 am
    I’ll do that thanks…
