Activity Forums Compression Techniques Compressing something down while keeping the alpha channel
  • Compressing something down while keeping the alpha channel
    Posted by Patrick Birks on December 10, 2012 at 11:56 pm
    So I’m trying to compress a video down that is 9megs down to about 20kb. The video has an alpha channel that I need to keep. I’m not really sure how I would go about this. I was hoping that I could set up the size of the video in after effects then send that to handbrake. But I guess when I do that I loose my alpha channel when I run it through hand brake. so does anyone have an tips or ideas that might help?
    Sareesh Sudhakaran replied 13 years, 9 months ago 3 Members · 2 Replies
  • Craig Seeman
    December 11, 2012 at 12:29 am
    I was considering a much longer response because I’m not sure you’re serious but the short version is “not possible” assuming I understand you.
    You must use a codec that supports alpha channel and I don’t know any encoder that is so efficient that can reduce a 9MB file to 20kb and have any kind of usable result. I can’t even imagine that workflow that would require that.
  • Sareesh Sudhakaran
    December 11, 2012 at 9:13 am
    A single frame will be about 20 kb, assuming you are using the correct notation. If you meant 20 kB, then the answer is simple: No, you can’t.
    If you wanted to try it for fun, I recommend compressing to a PNG image sequence. Audio separate.
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
