Activity › Forums › Apple Final Cut Pro Legacy › compressing software program to DVD
Posted by Jim Finn on January 31, 2012 at 8:00 pmI have an 80GB proRes file. I want to make a DVD but do not like the quality from compressor. This is a preview DVD so it’s not final but it does need to look really good.
MACPRO 2 x 3GHz Quad-Core
20GB RAMSteve Eisen replied 14 years, 7 months ago 4 Members · 6 Replies -
Michael Gissing
January 31, 2012 at 9:59 pmIf you are downscaling from an HD file, search this forum for advice on setting frame controls for best scaling in Compressor.I think it is in the FAQ as it has been asked a lot.
Any details on how you are driving Compressor and, as Dave asks, what length the program is will help.
Sascha Engel
February 1, 2012 at 7:36 amI do think Compressor does a pretty good job.
The problem could be indeed rather that it’s HD footage downscaled to SD.
With the right Compressor settings it will look a lot better.
My own workflow usually involves AE: I downscale it there to SD, which AE does an awesome job in,
and then I use Compressor to create the DVD file from that SD Version.Sascha
Jim Finn
February 1, 2012 at 12:12 pmWhat is AE? After effects ?
20GB RAM -
Steve Eisen
February 1, 2012 at 12:52 pmCompressor does an excellent job. Choose one pass CBR around 6.
If you want, Compressor will select the best setting for you by clicking on the gear.
If you do not feel that Compressor is doing a good enough job for you, look at Episode Pro, Sorenson or Adobe Media Encoder.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
