Activity Forums Compression Techniques compressing SD pal footage to HDV help
  • compressing SD pal footage to HDV help
    Posted by Dan Freshman on October 18, 2009 at 6:40 pm
    Hello,
    I’m trying to uprez a large quantity of SD pal footage to match the majority of footage I have which is HDV 1080p24. My tests have came out satisfactory using compressor and frame controls. However, I have about 33 gigs to convert and when I try to batch compress, it estimates the time needed to about 1100 hours. I am on a 2 x 2.66 dual core intel xeon w/ 5 gb of 667 ddr ram.
    Does this sound right? If so, what is the best method to go forward. Just offline edit w/ the pal footage and batch compress once the sequence is complete?
    thanks for any and all suggestions/help.
    dan
    Daniel Low replied 16 years, 11 months ago 2 Members · 3 Replies
  • Daniel Low
    October 19, 2009 at 5:58 pm
    [dan freshman] “I have about 33 gigs to convert and when I try to batch compress, it estimates the time needed to about 1100 hours”
    Tell us how many hours you have to compress rather than the total size 33GB in one format could be 1000 x longer than in another format.
    Could you also tell us what CODEC the source material is?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
    “We and Apple are neck and neck and we’re chasing the two
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • Dan Freshman
    October 19, 2009 at 7:34 pm
    It is DV pal. I have 30 clips total that add up to about 3 hours of footage.
  • Daniel Low
    October 19, 2009 at 7:48 pm
    Ok,
    Much of the estimated time given by compressor will be taken up by the upscaling of the SD footage and that time will vary considerably depending on what quality settings you have chosen for the upscaling.
    My suggestion is to take a short sample – say 10 minutes, and run it through the process at those settings while timing it. Simple maths will tell you how long the whole lot will take.
    other players,”
