Activity Forums Apple Final Cut Pro Legacy Compressing project to MPEG1 using QuickTime in FCP
  • Compressing project to MPEG1 using QuickTime in FCP
    Posted by Jd Funari on May 16, 2005 at 2:34 am
    Hello CC,
    I need to compress a project in FCP to an MPEG1 DVD file for a client in addition to standard MPEG2 DVDs. I do not see an MPEG1 compression option under QuickTime Conversion settings. I unsuccessfully tried compressing as a Motion JPEG A.
    Can someone drop some knowledge on this process?
    Thank you!
    J.D. Funari
    The Spark Factory
    Jd Funari replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
