Activity Forums Compression Techniques compressing HD progressive to SD interlaced for broadcast with compressor
  • compressing HD progressive to SD interlaced for broadcast with compressor
    Posted by Sean Schiavolin on November 29, 2008 at 9:01 pm
    Anyone have a solid method for encoding progressive HD (DVCpro HD 29.97) to interlaced SD for broadcast delivery?
    I’m using DGfastchannel and their spec’s require 480 60i (upper field first) which is causing some serious tearing.
    I’m using compressor to encode and viewing the .mpeg with VLC.
    Sean Schiavolin replied 17 years, 9 months ago 3 Members · 2 Replies
  • Daniel Low
    November 29, 2008 at 11:02 pm
    “480 60i (upper field first)”
    That maybe not quite right:
    https://forums.creativecow.net/thread/20/858832
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Sean Schiavolin
    November 30, 2008 at 1:08 am
    as long as there’s no issues with delivering a progressive version I’m happy. DG has accepted my compressor encodes even though it’s not 4:2:2 chroma.
