Activity Forums Compression Techniques Compressing for Vimeo / Strobe Effect Lost / Dropped Frames
  • Compressing for Vimeo / Strobe Effect Lost / Dropped Frames
    Posted by Jesus Rivera on October 12, 2010 at 9:13 am
    Hello,
    I recently composed a video installation for an art show. I am having trouble getting a proper compressed version for the web (Vimeo, Youtube). The video is very experimental and contains alot of frame by frame strobing effects (1 frame solid color, next frame video image…back and fourth for seconds at a time) and it is not translating correctly when I compress it via Apple’s Compressor program.
    I am hitting a brick wall and don’t know what to do.
    The master hi-rez file is as follows:
    DVCPRO HD 720p60 960×720 (1248×702)
    23.98 fps
    My export setting are as follows:
    H.264 1280×720
    Pixel Aspect Ratio = Square
    Frame rate = Current
    Key Frames = Every 30 Frames
    Frame Reordering On
    Data Rate = Restrict to 5000kbps
    Now I have tinkered around with the Data rate & key frames multiple times and it gives me the same thing. Dropped frames when viewing in Quicktime. Is there a specific process that can handle frame by frame strobing effects???
    Please help!!!!
    Thanks!!!
    Jesus Rivera replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
