Activity Forums Compression Techniques Compressing for USB TV playback
  • Compressing for USB TV playback
    Posted by Les Kaye on December 8, 2009 at 8:14 am
    I’ve got some DVCPro 1080i & 720P videos that I’d like to encode for direct USB playback on a Samsung HDTV, which does NOT support quicktime, although it does support mp4 and H264. I want to keep the same HD dimensions.
    I’ve tried exporting directly from QT to MP4, but the results are totally unsatisfactory. FCP using QT Conversion takes forever (6 min file). I’m now trying Compressor with the Apple TV setting and that’s going a bit faster, but still taking awhile.
    Would Handbrake be a better choice in terms of quality and speed? Should I change my choice of codec?
    -L
    Les Kaye replied 16 years, 9 months ago 2 Members · 2 Replies
  • Daniel Low
    December 8, 2009 at 8:39 am
    [Les Kaye] “Would Handbrake be a better choice in terms of quality and speed? Should I change my choice of codec?”
    Most likely, give it a try, it’s free!
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
  • Les Kaye
    December 10, 2009 at 8:08 am
    Thanks for the advice, but unfortunately I had issues with the Handbrake exports: Either the video plays back in slomo (if I keep the same source fps settings), or else it just stutters and freezes (if I choose 29.97 as my output). And this was just on my late model MBP. Finally, even though I chose MP4 as my output choice, the file could not be read by the Samsung (LN52B750, for those curious) – even though other MP4 files are playable.
    While I’m at it, I also tried doing an export of a different DVCPro HD project using the new Share function in FCP. I chose Blu-ray as my choice, and the file has the option that it can only be opened by Compressor. However even after 2 separate exports, I get: “Error trying to open source media file.” when I try importing the file into Compressor.
    Sigh… (and thanks).
    http://www.leskaye.net
