Activity Forums Apple Final Cut Pro Legacy Compressing for DVD – QT Error 0
  • Compressing for DVD – QT Error 0
    Posted by Neal Fox on November 26, 2010 at 7:09 pm
    I was able to make an mpeg 2 file for DVD and all worked fine.
    I made one very small change in the video and needed to compress it again. Now it goes for about an hour then quits and I get a QuickTime 0 message. Here’s how I’m doing it:
    1. Export to Compressor from FCP.
    2. Pick the preset for the DVD ( picture only – audio works fine)
    3. Submit and close Compressor.
    I thought maybe the project was too big because I’ve got several sequences with it. But I made an Media Manager Copy to another place so it would be by itself and still got the message.
    Help!
    Jerry Hofmann replied 15 years, 10 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    November 27, 2010 at 12:02 am
    Try exporting a self contained QT movie of the sequence, and import that file into Compressor using the settings you’ve used before.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Neal Fox
    November 27, 2010 at 1:44 am
    That worked.
    The weird thing is that I only changed one letter on a text slide. It worked fine before that.
    Thanks.
  • Jerry Hofmann
    November 27, 2010 at 5:27 am
    Possibly re-rendering that bit would have done the trick.
    Jerry
    Current DVD:
