Activity Forums Compression Techniques compressing a music video
  • compressing a music video
    Posted by Aria Slade on April 5, 2006 at 5:35 am
    using a Mac, I edited a music video in and exported from Adobe Premiere, then exported from Adobe After Effects to convert it to .avi format.
    unfortunately, to upload the video onto a website, it must be under 100 MB – but the file is around 540 MB.
    how can I compress this?
    Daniel_l replied 20 years, 4 months ago 3 Members · 4 Replies
  • Ben Waggoner
    April 5, 2006 at 6:17 am
    If you’ve got the final edit in Premiere Pro, you can use Adobe Media Encoder to make a .WMV file. For download, use 2-pass VBR. How long is the video? 50 MB should be enough for decent quality if it isn’t too long.
  • Aria Slade
    April 5, 2006 at 10:02 am
    the video is 3:40 long, thanks!
  • Aria Slade
    April 9, 2006 at 9:07 am
    is there any way to do this using Adobe After Effects? Because I’m having trouble finding the Media Encoder for Mac anywhere.
  • Daniel_l
    April 11, 2006 at 11:04 am
    Ideally you need one of the following applications to produce a decent quality compressed version – AfterEffects won’t do the job for you.
    Sorenson Squeeze
    PopWire Compression master
    Autodesk cleaner
    Apple Compressor
    FFMPEG
    DL
    Video AllSorts
