Activity › Forums › Apple Final Cut Pro Legacy › Compressing a large file!
  • Compressing a large file!
    Posted by Lindsay Rice on May 8, 2008 at 1:05 pm
    I have a 3 hr. 45 min. video I need to somehow compress to fit on a DVD (preferably without totally sacrificing all of the quality). I’m only experienced with Compressor for small 10 min. videos. Can I use it for this, what’s the best setting?
    Mark Maness replied 18 years, 4 months ago 4 Members · 3 Replies
  • Steve Eisen
    May 8, 2008 at 2:00 pm
    Set your bit rate around 1-2. Quality won’t be that great but if you want to fit close to 4 hours on 1 DVD-R, you are sacrificing quality.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jeff Carpenter
    May 8, 2008 at 2:26 pm
    Make sure you use the variable bit rate setting. Set it around 2 average and 4 max. Also make sure you’re making a Dolby audio compression to save space there.
    Then, see what file sizes you get.
    If it’s a sporting event you might barely make it. If it’s all talking heads you may find it comes in under 4 GB and you can then raise the compression and try again. For something of that length you’ll probably end up compressing 3 or 4 times, each time trying to get it as close to 4.1 GB as you can.
  • Mark Maness
    May 8, 2008 at 9:58 pm
    Have you considered a dual-layer DVD?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
