Activity Forums Compression Techniques Compressing a FCP file
  • Compressing a FCP file
    Posted by Rachel Miller on July 26, 2011 at 11:46 am
    Hello,
    I tried several times to compress a file that is 6 minutes and 33 seconds long. I changed the settings to 24 FPS and I changed the size to 853 x 480. The file is still too big. I’ve also tried to export it at a lower resolution using NTSC 720 x 480 16:9 and NTSC 720 X 480 4:3. I have kept the compressor quality slider at Best. I need the file to be no bigger than 250MB This has been a very difficult task. I am converting the file to a quicktime movie. This file is to be uploaded to a website.
    Please advise.
    Rachel
    Craig Seeman replied 15 years, 2 months ago 3 Members · 2 Replies
  • Mark Spano
    July 26, 2011 at 3:26 pm
    Some math is in order to figure out what bit rate you should encode at to hit a size target. If your file needs to be (let’s say) 200MB, then using H.264 compression, your total bit rate should be around 1500 kbps. I got that figure from this calculator:
    here
    Obviously you will have to test to make sure you hit the size, but it sounds about right to me.
  • Craig Seeman
    July 26, 2011 at 3:28 pm
    Data rate controls file size for the most part.
    Compressor’s summary tab will show you the estimated file size per one hour so you’d have to do a little math to find the approximate file size. I generally find Compressor’s estimate to be as much as 10-20% smaller than the resultant encode.
    You should use a bitrate calculator.
    https://www.pimley.net/projects/#bitratepro
    or
    https://itunes.apple.com/us/app/vidbitcalc/id447847515?mt=8
