Activity › Forums › Apple Final Cut Pro Legacy › compressing a 7 minute movie
  • compressing a 7 minute movie
    Posted by Laura H on August 23, 2006 at 5:37 pm
    Hi, I’m trying to find the optimal compression settings for a movie I’m exporting from FCP. I’ve been using Cleaner 6 to compress but I can’t seem to get the file size down with compromising the quality of the film. Unfortunately, my client would like to have this movie embedded in a PowerPoint presentation (it will be running off a mac). I’ve been compressing using the animation codec and have reduced the dimensions to 320×240 but the file is still huge (over a gig). Can anyone supply some alternative settings for me? When I export from FCP I use the animation codec, 24fps, keyframe every 300. HELP!
    Many thanks
    Laura
    Rennie Klymyk replied 20 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • Mark Maness
    August 23, 2006 at 6:36 pm
    Export to H.264 – Apple uses this for all of their movies.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Jeff Carpenter
    August 23, 2006 at 6:41 pm
    Check to see if your client has Quicktime 7 on their machine.
    If so, use the “Export -> Quicktime Movie” right in the Final Cut menu and give this a try:
    Video:
    H.264
    480×360
    Quality = Medium
    Audio: AAC
    Mono (unless stereo is really needed)
    Bit rate 128 kbps
    Sample rate 44.1
    That’s just a starting-off place. You’ll probably have to re-adjust settings once you see how that works out for you. If it’s way too big, take the size back down to 320×240. But I’d try it with the slightly larger size first.
    The final size depnends on the motion in the video, but you should be able to do pretty well. Here’s an example of a 40 second video (at that frame size) that comes in at 2.5 MB.
    http://www.penguintail.com/parrot
  • Laura H
    August 23, 2006 at 7:15 pm
    thanks Jeff, it worked beautifully!
  • Jeff Carpenter
    August 23, 2006 at 7:31 pm
    Glad it worked.
    I didn’t say earlier, but just so you know…the animation codec is the exact opposite of what you wanted. It’s very good at preserving quality…it keeps each frame intact. It’s not concerned with saving space at all, that’s not what it’s made to do. That’s why you were having such bad luck!
    H.264 is very good at saving space…it’s actually a version of MPEG-4. It only plays in Quicktime 7 or iTunes, however. If you’re dealing with Quicktime 6 then go with H.263. It doesn’t look as great, but it’s more compatible with more systems.
  • Rennie Klymyk
    August 23, 2006 at 7:38 pm
    I thought power point wouldn’t handle H.264 files. Don’t you have to go with flip 4 mac = wmv for power point?
    “everything is broken”
  • Jeff Carpenter
    August 23, 2006 at 7:44 pm
    I had assumed (always a bad idea, I know) that Powerpoint could just tap into Quicktime and play anything it could. This is the Mac version she’s talking about, after all, not the Windows version.
    But you raise a goopd point, Rennie! Can you test this, Laura?
    I could test this for you tonight if you need, and report back. (I only have Powerpoint on my home computer, not here.) Let me know.
  • Laura H
    August 23, 2006 at 7:47 pm
    Just tried it and it looks great —- fortunately it will be shown on a mac and not distributed to our PC-based company.
  • Laura H
    August 25, 2006 at 7:52 pm
    I’m looking for compression settings that will make this file as tiny as possible. So I’m exporting from FCP, I’d like to keep the video @ 400×380, (thanks to Jeff Carpenter for the dimensions). Does anyone know of decent compression settings in .avi format? it turns out they’ll be showing this in PowerPoint on a pc. thanks for your help
  • Rennie Klymyk
    August 29, 2006 at 5:39 am
    [Laura H] “I’d like to keep the video @ 400×380,”
    Opps, don’t you mean 480×360? 400×380 is basically square.
    It’s been a long time since I did anything for powerpoint but it seems to me most everything on that side is windows media.
    Check out this earlier thread-
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=902734&forumid=8&postid=902907&pview=t
