Activity Forums Compression Techniques Compressing 30GB AVI
  • Compressing 30GB AVI
    Posted by Jordan Abbey-young on May 29, 2010 at 7:06 am
    Hey Guys,
    I’m at my wits end, I use Sony Vegas 9 to create a 2hour 24 Minute, 30GB Movie file for a local Motorbike Rally Weekend Event.
    I need to get it burned ASAP but I unable to do due to DVD Architect not burning such a large file for me.
    I have tried Optimize DVD but I don’t know what the benefits of changing the bit rate is so I only tried Fit To DVD for everything and the large files tell me they are too big.
    How can I compress this file so the space on the 8.5GB disc does not read 122% Space Used.
    Any help is appreciated!
    Life’s about being entertained.
    Brian Alexander replied 16 years, 3 months ago 3 Members · 3 Replies
  • Daniel Low
    May 31, 2010 at 12:35 pm
    [Jordan Abbey-Young] “How can I compress this file so the space on the 8.5GB disc does not read 122% Space Used. “
    Use the DVD standard – MPEG-2
    Sent from my iPad Nano.
  • Jordan Abbey-young
    June 1, 2010 at 1:00 am
    Problem Solved:
    How: When the Menu is created in DVD Architect, with oversized files and all. Burn an ISO Image.
    Download DVDShrink and use the program to create a version of the ISO image where it will fit to the selected Disc Size, in this case a 4.7GB Disc.
    Using a burning program, my ISO image came up with the symbol for Roxio so I used that, to burn the ISO image to disc.
    You now have your DVD with everything you intended on it, without major if any quality loss.
    Worked for me!
  • Brian Alexander
    June 2, 2010 at 1:18 am
    This is not the way a compressionist goes about getting content to fit onto a DVD.
    The idea is to compress media (video, audio, animation, gfx, etc.) with compression software. The amount of compression depends on 2 factors: File Size and Quality. The point is YOU control the compression, not software.
    That said, when we’re in a pinch, we do what we can to find what works and we make it work. Next time you may run across across the practice of bit budgeting. Have a look at this: Bit Budget
    Brian Alexander
    Sr Video Engineer
    Freeman AVS
