Activity › Forums › Adobe Premiere Pro › Compressed output looks like *$#(@!
  • Compressed output looks like *$#(@!
    Posted by John Phillips on August 30, 2011 at 3:41 am
    Hi all,
    I just finished editing a sequence of short videos in HD shot on an Sony XDCam EX1 and edited in Premiere 3.2. I edited the videos in 1080p and then compressed them using Sorenson Squeeze and an H264 compressor for web distribution. The videos looked reasonably sharp while in Premiere but the output after compression looked awful. The graphics and the video were extremely soft – almost looked out of focus – and significantly hotter than the source footage. Any suggestions on what I’m doing wrong?
    John Phillips
    Kevin Monahan replied 15 years ago 4 Members · 9 Replies
  • 9 Replies
  • Jeff Pulera
    August 30, 2011 at 9:09 pm
    Hi John,
    How did you get the edited video from Premiere over to Squeeze?
    What are the export encoding settings – frame size, data rate, etc.?
    Have you tried exporting to H.264 directly from Premiere?
    Jeff Pulera
    Safe Harbor Computers
  • John Phillips
    August 31, 2011 at 6:18 am
    Hi Jeff…
    I exported the movie as an uncompressed .avi file and then did the compression.
  • Jeff Greenberg
    September 1, 2011 at 3:23 am
    What setting did you use in squeeze?
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • John Phillips
    September 1, 2011 at 4:42 am
    I output the squeezed file to a Quicktime movie at 768Kbps.
    Stream Type: Non-Streaming (Not Hinted)
    H.264 Codec
    1 Pass CBR
    Frame Rate: 1:1
    Unconstrained Frame Size
    Frame Size: Same as Source (1440 x 1080 16×9)
    Automatic Data Rate
  • Jeff Greenberg
    September 1, 2011 at 3:18 pm
    I think your problem is this: [John Phillips] “768Kbps. “
    For HD of this size, you’re probably going to need to change that to around 3000-5000 kbs. This will make the resulting file at least 5-8x larger.
    I’d also probably switch the 1Pass CBR to 2pass VBR
    Hmm – at the bottom you’re set to Automatic Data rate as well, that shouldn’t be. Either your at a specific data rate (768) or a generic setting (Automatic).
    Best,
    Jeff G
  • John Phillips
    September 1, 2011 at 8:10 pm
    OK, the problem with that is the file was destined for the web. Is there a way to achieve more compression without sacrificing quality so greatly? I know I’m asking for the world but I have seen files from the web that weren’t huge yet looked great. This one was neither.
  • Kevin Monahan
    September 6, 2011 at 8:14 pm
    Drop the frame size to something less than HD size. That will drop your file size.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • John Phillips
    September 6, 2011 at 8:20 pm
    In your experience what size would you suggest is ideal for web delivery?
  • Kevin Monahan
    September 6, 2011 at 9:28 pm
    Try it at 1/2. 960 x 540.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
