Activity › Forums › Apple Final Cut Pro Legacy › Compressed file to large
Posted by Matt Jones on February 9, 2010 at 3:10 amUsing FCP 6. Anyone know a good way to compress an hour and one half standard-def video to under 7 gigs(or smaller) in either FCP or Compressor, while still retaining good quality for a DVD. I don’t need MPEG2, just any file Toast can author.
John Fishback replied 16 years, 3 months ago 3 Members · 6 Replies -
Matt Jones
February 9, 2010 at 3:44 amOk, I’m trying an H.264 Streaming with 640×480. I’m assuming it will horrible when authored in Toast. The weight in my timeline is super huge, because a good portion was converted in MPEG Streamclip. That section alone was like 12 gigs.
Matt Jones
February 9, 2010 at 4:12 amOk, i gave up on the H.264 Stream. What I am doing now, is exporting out of FCP as a regular QT export. File size should be around 16 gigs or so.
I may try using Sorensen Squeeze, with a Pro Res 422 codec. Could that get me down to under 4 gigs or so with ok quality? -
Matt Jones
February 9, 2010 at 5:17 amOk, its looking like around 13 Gigs. Can Toast compress that to a watchable size?
Rafael Amador
February 9, 2010 at 5:23 amMatt,
To put 90 minutes of picture in 4GBs, MPEG-2 and H264 are the options.
You should learn to calculate what data rate you need to get a file of a certain size.
Meanwhile you can use “Handbrake”. You just need to tell him how big you want the exported file.
Is a very simple GUI with a powerful h264 compressor inside (x264).
Rafael -
John Fishback
February 9, 2010 at 5:12 pmBe sure to use ac3 audio, not aiff. You will gain over 1mbps bandwidth. Checkout Videospace – freeware from Digital Heaven.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
