Activity › Forums › Apple Final Cut Pro › ‘Compress>Archive’ FCPX10.09 App, save zipfile… can I install this on Mavericks MBPro later?
  • ‘Compress>Archive’ FCPX10.09 App, save zipfile… can I install this on Mavericks MBPro later?
    Posted by Stephen Underwood on May 16, 2014 at 12:04 am
    Hi, Selling an iMac with FCPX 10.09 on it. (About to wipe the drive). I’d like to be able to install this older version on my new MBPro (running Mavericks w/FCPX 10.1) if needed later. Can I do this? If not, please advise on how to archive the older version. Thanks!
    ~ Steve Underwood
    Computer: MacBook Pro, OS X 10.9.2
    Processor: 2.6GHz, Intel Core i7, Memory: 16GB
    Intel Iris Pro, NVIDIA GeForce GT 750M, FCX 10.1.1
    Pegasus 4TB RAID
    Marco Feil replied 12 years, 4 months ago 3 Members · 3 Replies
  • Andy Neil
    May 16, 2014 at 12:43 am
    You can’t have both versions on the same system drive, but you can save and reinstall 10.09 by zipping it up. I have all the old versions of FCP archived in this way.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Stephen Underwood
    May 16, 2014 at 1:11 am
    Thanks for the info and the reassurance!
    ~ Steve Underwood
    Pegasus 4TB RAID
  • Marco Feil
    May 16, 2014 at 11:51 am
    You can have both installed on the same drive, you just need to rename one of the Apps, like “Final Cut Pro 10.0.9.app”. I always backup and rename or delete “~/Library/Application Support/Final Cut/” and all the Final Cut Prefs in “~/Library/Preferences/” before I use the older Version.
