Activity › Forums › Compression Techniques › Compress to very small file
Posted by Terry Moore on August 7, 2007 at 2:20 pmI have a 52 second video clip that I need to compress to an .mpg that is 2megs or less. I can’t seem to get it under 3megs. Any suggestions?
The clip was edited in FCP and I’m using Compressor 3.0.1.
Thanks.
Terry Moore replied 19 years, 1 month ago 4 Members · 9 Replies -
Rich Rubasch
August 7, 2007 at 4:47 pmAre you looking for an MPEG-1 or an MPEG-2 file? Or an MPEG-4?
What are your current settings?
Rich Rubasch
Tilt Media -
Terry Moore
August 8, 2007 at 2:04 pmIt needs to be an MPEG-1 file. I’m not sure what you mean by my current settings. I have made about 20 files with different setting and can’t get it below about 4.5MB. I have even varied the file type and size when exporting from FCP so I start out with a smaller file in Compressor.
I am new to Compressor but have changed about every setting I could think of to reduce the file size with no luck.Thanks for replying to my request. Hopefully this added info will help you help me.
Daniel Low
August 8, 2007 at 3:05 pmI don’t use compressor anymore but I’ve used Episode to create a bunch of 1 minute MPEG-1 clips that came in at about 2.4MB.
Settings:
Video
192×144
25fps
250kbit/sAudio
32kbit/s
Mono
22050HzThey didn’t look ‘too’ bad either 😉
Ben Waggoner
August 8, 2007 at 3:53 pmThat’d work.
2 MB in 53 seconds requires
(2 MB * 8000 Kb/MB)/53 sec = 301 Kbps
My compression blog: https://on10.net/blogs/benwagg/
My compression class at Stanford: https://digitalmediaacademy.org/courses/video-compression-training.html
Terry Moore
August 8, 2007 at 4:06 pmThank you for all your posts. However, I still don’t think my question has been answered.
How do I do it????
I understand how it works mathematically. But when it comes to actually making the file in Compressor, how do I do it? What settings do I need? I have reduced everything to the smallest setting I can find but still end up with a 4.6MB file.
Daniel Low
August 8, 2007 at 8:28 pmCan you supply us with a detailed run down of what settings you have now that give you the 4.6MB file?
Terry Moore
August 8, 2007 at 8:55 pmStarting with an .mov file exported from FCP.
Placed into Compressor v3.0.1
Dragged and dropped MPEG-1 setting from MPEG-1 preset folder
In the Inspector I changed from DVD to Web and reduced Bit Rate to 0.50 (the lowest it will go)
That is all the settings that I can change (except for Cropping which I don’t want to change).Back at the Inspector Summary it tells me that the Estimated file size is 4.44MB
Here are the other settings displayed in case it helps:File Extension: mpg
Audio Encoder:
Format: MPEG
Sample Rate: 48 kHz
Channels 2
Bits Per Samle: 16Video Encoder:
Format: MPEG1
Width and Height: Automatic
Selected: 320 x 240 (I was unable to change this setting)
Pixel aspect ratio: Square
Crop: None
Padding: None
Frame rate: (100% of source)
Selected 29.97
Frame Controls: Automatically selected: Off -
Daniel Low
August 9, 2007 at 7:42 amLooks like you’ve hit one of the limitations of compressor; if you can get the frames size set to smaller than 320×240 and the datarate to lower than 0.50(?) then you’ll not get the file sizes you need.
An investment in Episode is a good investment. As far as I’m concerned it’s a far more capable encoder.
