Activity Forums Apple Motion Compress Keyframe timing
  • Compress Keyframe timing
    Posted by Kb Burnfield on June 19, 2019 at 1:38 pm
    I’ve got an animation I’m working on and it’s 10 seconds long but after working on it I realize it would be better at 5, what I’ve done in the past is export it and in FCPX I just speed it up but I recall there’s a way to go into the keyframe editor and “compress” the time or distances between keyframes…. isn’t there?
    I can’t find any reference to this anywhere online so I thought I’d ask.
    thx
    Kb Burnfield replied 7 years, 2 months ago 2 Members · 3 Replies
  • Simon Ubsdell
    June 19, 2019 at 6:06 pm
    Draw around the keyframes using the Transform Keyframes Tool (highlighted in blue) and then you can adjust the resulting bounding box to resize the animation.
    Simon Ubsdell
    hawaiki
  • Simon Ubsdell
    June 19, 2019 at 7:40 pm
    Of course, if you don’t have 3D groups you could always make a master group for your entire project and put everything inside it.
    If you then make a Clone of that group, you can retime it using either the Retime Behaviors or by keyframing the Timing controls for the group.
    Simon Ubsdell
    hawaiki
  • Kb Burnfield
    June 20, 2019 at 1:06 am
    THANKS!!!
