Activity › Forums › Compression Techniques › compress in MOV so it’s the lightest possible
  • compress in MOV so it’s the lightest possible
    Posted by Marianne Souliez on July 9, 2012 at 1:50 pm
    hello,
    I have to deliver MOV videos, the longest is one hour, and they are designed for download so they have to be the lightest possible. The image size is fixed (476×268). The soundtrack is just voice.
    So far the only parameters that I have adjusted are the compression codec (I chose H264) and the sound (44Hz instead of 48). I know that Compressor, which is the tool I have, has other parameters for the compression, but I have no idea which to tweak to get lighter files.
    Can anyone give me a preset that is pretty optimal?
    Thanks a lot!
    Marianne
    Eric Strand replied 14 years, 2 months ago 2 Members · 1 Reply
  • Eric Strand
    July 10, 2012 at 2:34 pm
    You’ll want to tweak the data rate. Your video is so small you should be able to lower the data rate to 400-500 kpbs.
