Activity › Forums › DVD Authoring › compress from timelime vs. quicktime
Posted by Chris Wasmer on October 20, 2008 at 1:40 amHow does one get a better quality DVD?
Export an MPEG2 from the FCP timeline or export a same settings QT and make MPEG2 of that?
If QT, reference or self contained?
I am using Compressor.
Thank you.Noah Kadner replied 17 years, 11 months ago 2 Members · 5 Replies -
Noah Kadner
October 20, 2008 at 12:06 pmKinda depends on the source- if it’s HDV for example- definitely do not recompress with current settings. Also depends if there’s a downconversion involved first. If I’m coming from 720p DVCPROHD for example I typically go to 16:9 SD ProRes HQ first out of FCP and then convert to MPEG-2 in Compressor. As far as how to get better looking final DVDs- that depends a lot on the level of quality of the source footage. Also Compressor itself is not the only MPEG-2 encoder. There’s also Bitvice, Cinecraft, etc.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
https://www.callboxlive.com -
Noah Kadner
October 20, 2008 at 9:10 pmThen pretty much same workflow I’ve outlined above would do the trick.
Noah
Chris Wasmer
October 20, 2008 at 9:36 pmI will give it a try.
But it seems odd to me to introduce another codec (prores) into it. -
Noah Kadner
October 20, 2008 at 10:09 pmIt’s what I do but you can compare results to Uncompressed as well. The most important thing is the downconvert anyway. To go directly from DVCPROHD in FCP into Compressor with the downconversion ties up FCP forever with not much difference in quality.
Noah
